looks good!
:ditto: on what Mike said!! :thThumbsUThe new tires look great. :trink39:
Probably would have but I could not find 8" diameter in HDAP type.Very nice!!
I really like the look of the All-Trails. Any reason why you didn't put them (or Field Trax) on the front too?
I hope to be showing off some new rubber in the next couple weeks, too.
I found this site and they seem to have alot of brands to choose from.Just put your tire info in, nothing else and hit veiw tires below.Got new tires for my 425 and thought I would post some before and after shots.
First 3 before last 3 after. New Tires I went with are Carlisle all trail 25x10.50x12 4ply on rear and Carlisle multi trac 18x7x8 4ply on front. Gained @ 1.5" on rear and @ 1" on front. Also changed rear wheels to wide stance. Come on snow!!!!!!!!
Max psi on rear tires is 20 and front is 26. I assume this is too much? Any ideas on what psi I should run in these?
Ahhh, got it.:fing32: I had thought your tractor had the same front rims as the X700s. Regardless, your set-up looks really sweet! You must be psyched (if only you could test it in some snow, right?)Probably would have but I could not find 8" diameter in HDAP type.
