so i'm looking at buying a 425. owner says it has low compression. its a 94, so i think it has a plastic cam. i don't mind having a winter project to work on, especially if i end up with a tractor i can put a FEL on eventually.
so, could the plastic cam be causing the low compression?
is there anything else i should look at when i see it in person (without taking anything apart)?
