I am noticing that in 2nd gear high range that I'm getting a squeal as I let the clutch out. Toro belt is a year old. It goes away when underway, but that initial slipping of the clutch is beginning to annoy. Only get it in 2nd and 3rd high, after belt warms up.
I can't remember if there is an adjustment for the clutch. Just a pedal adjustment I think. I also don't use that clutch spring dampener, took that off when I did the restoration. Maybe I should put that back on... What do you think?
I wonder if this past year pushing snow may have worn the belt... but I don't know... these WH's can go years on a belt.
