1 - 2 of 2 Posts
I have a jd 4100. I am going to install a electric snowblower chute control ( up down control of chute).
What hot wire is only on when the key is on and will be adequate to splice into for the electric chute? There are several wires (as you look at the front of the tractor) on the left back upper side of the firewall. Expedited replies appreciated.
Kish JD 318/420/430
Should come from either the fuse block or the battery with an in-line fuse to a momentary DPDT switch that is wired correctly and run out along frame to SB frame to actuator. Hope you got a sealed actuator.
1 - 2 of 2 Posts
