1 - 11 of 11 Posts
I've noticed in pics of some of the later model 4 wheels, they use springs to assist lifting the mower deck. I have the springs and clasps for use on my snowblower. I can tell that I would need to mount studs in the existing threaded holes, and from the pics, I think I see where it mounts to the deck (there's an unused hitch point with two pin-holes per side). But it doesn't seem like that point would help with the lifting. Does anyone have a pic of the springs mounted on their tractor?
(Sorry, kinda a convoluted post... thanks in advance.)
· Banned
The GRAVELY Lift Assist Kit springs install using "studs in the existing threaded holes" on sides of frame & via connecting links to the "unused hitch point(s) with two pin-holes per side". And YES, this geometry doesn't provide a lot of mechanical advantage.
However, despite GRAVELY's recommendation for use w/manual lift, their advertising frequently shows the Lift Assist Kit installed on hydraulic lift tractors. I'd presumed the 'Assist' also provides some help in antiscalping.
Your tractor should have hydraulics on it so there is no need for the spring assist. It was made to help raise the deck on tractors without hydraulics.
I sure wish I had hydraulics! Unfortunately, I'm all manual.
Banger,
Thanks for confirming that.
Does anyone have a pic of the linkage that connects the spring to the deck hitch points?
It is not realy linkage just a piece of steel about 4 inches long, with 2 holes. One goes over the pin on the deck and the other is for the spring to pass thru. ED
You wouldn't happen to have a picture, would you?
I went out this a.m. to get you a picture. Instead I made you up a pair, They are the same as the stock one but a little thicker. They should work the same as the original I copied. If you send me your address I'll send them out asap when you get them send me a check to cover the postage and whatever you think they are worth. I'm in northern Ma. Happy mowing Ed.
Discussion Starter · #9 ·
Ed,
That is extraordinarily generous. Thank you very much.
You have a PM!
:thanku:
Discussion Starter · #10 ·
Sorry I've been late getting back to this.
I received the brackets from Ed in the mail. Excellent workmanship! They fit perfect and do exactly what I want. He even went as far as to paint them red!
Ed, you are a gentleman. (payment went out yesterday -- sorry for the delay.)
For anyone interested -- here are a few pics.
Again, thank you Ed!
1 - 11 of 11 Posts
