it's pretty straightforward removal - the svc manual will be some help but the only issue i had in taking one off was it was frozen on (after 20+ years of having been on the shaft) and all the kroil and alternate heating didn't help
i managed to bend the pulley where the puller claws grabbed the pulley - it's awkward to get a good hold on it, you end up using the pulley to pull on and the pulley has zero heat treat - it's soft metal
you will need to remove the radiator but that's relatively minor affair
having pulled it off one time (almost 1.5 years ago) i need to revisit it to see if there wouldn't have been a better way, ie maybe some wedges tapped in behind the rear plate of the pto assy, forcing it forward rather than pulling on the pulley -
i'll try to look at it this evening and post later if i can see anything i'd have done different
but getting a copy of the svc manual is probably the smartest step at this point. 2nd, i'd do a search on this forum for earlier postings on this subject
as i posted one time before, the shaft diameter on the engine is 1.0" so a US made electric PTO should work fine - i've thought about replacing mine with one with a slightly larger diameter PTO pulley to get a little higher cutting blade speed so i can get a cleaner cut in 3rd gear
but that's a topic for another thread
