I've got one of each but can't figure out the difference? They're about equal cosmetically but I can't figure out how one might be better than the other to mount on my 214. :fing20:
Good eyes. You are correct that the rod I am using is not the correct one. I picked up the 37A without a lift rod and when I priced them from JD they want $50! for one like the pic PA318Guy posted :thSick: So as I parted DeereZilla down I found that rod as I pulled out the lift linkage and the lightbulb went off - set it next to the correct lift arm I got with my 37 blower and :fing32: same size. That's why I'm still confused why this whole rig won't work. :banghead3I have never seen a lift rod for the snowblower that was made from round stock. Are you sure that isn't the lift rod that goes under the tractor from the handle shaft to the rock shaft?
