I Took a Brass (act.Welding Rod) 5/32" welding rod.36" long Made a Small hook on one end and a larger Handle on the other. so I could Hook the spring and Pull it . You can manouver it back on. It may test your pashance; Or what ever.. Life is good;
I do it the same way. I lay on a piece of cardboard or my creeper and put one foot against the rear tire. I grip it with both hands and just pull it forward and off. It just takes a lot of grip. The mechanics gloves is a good idea, I will have to try that next time.Old thread, but.... I just grabbed it and pulled it off, then going back on grabbed it after hooking the rear floating hook and put it back on. I wore mechanics gloves and grabbed it ~ 1" from the hook. Just block the tractor wheels or make sure the brake is set. Maybe my spring is weak? 'Cause I know I am.
