Yes, you can lift an implement with the hydraulic lift. You will need to install a front lift kit if it does not already have one. A front lift kit basically adds a new location for the brackets to lift from and attaches to the snowblower or blade mounting points.mi fiveo -
Then I assume there is no way to lift a blade and or snowblower on the front end?
Thanks for your help!!
