1 - 1 of 1 Posts
1993 Case 3220-
Original symptom was- 3 point with Bush Hog attached would not go down, bucket was slow, vapor in transmission and smelled hot.
Steps taken- changed filter- worked up and down once and then stayed up.
Changed fluid and fitter again. Took Bush Hog off. Now 3 point lowers after sitting a day but raises as soon as tractor is started. The bucket works fine since filter was changed.
I believe the issue was caused by lack of maintenance. The old fluid was dark and thick. The new fluid is clear and thin.
Thanks in advance for any ideas or documentation.
1 - 1 of 1 Posts
