I was having starting issues with my 322 with the 18hp 3 cylinder Yanmar. Accidentally left the key turned to on, came back and cranked it while the cylinders were apparently full of gas. When I finally corrected my starting problem, when I reved the engine or under load there was a loud banging. I figured I threw a rod. I shut it down.
The motor has approx 2800 hours. It was a well-maintained commercially used machine before I bought it 15 years ago.
Question: What is my most likely damage and the best way to proceed?
Additional info; I just moved from a home with 1+ acres of zoysia to a house with a total land area of 8,000 sq ft so my plan is to sell or swap the tractor for a motorcycle.
I'm in St. Charles, Missouri.
Thank you in advance for all for the help and deserved ridicule.
