1 - 9 of 9 Posts
The Gate Keeper
My 1991 318 seems to be using a lot of oil lately. I am seeming to have to add about 1/2 a quart after every couple of mowings. Is this a rebuild or am I looking at something else? I am using 30 weight Pennzoil. Ideas?
what motor is in it ...It could be rings ..It could be valve seats, head gasket ,,Crank case vent not working right ,,I have had a few with leaking oil seals and base gaskets ..dose it smoke bad any signs of an oil leak any where
Three of my friends
could be rings,they wear out before the cylinder,change to JD Tuf Gard ,see what happens,does it smoke?
The Gate Keeper
It gets the usual puff of smoke on start up, but nothing major and it only lasts a little bit when you first turn it on.
FWIW, Onan manual recommends 40w above 80 degrees and 50w above 90
Not to say your engine isn`t worn, however it will slow down consumption
I assume it`s hot in Iowa this summer ?
I wouldn't worry about it unless it starts smoking continuously or loses power. I fill mine up every time I mow, may take 3 or 4 ounces depending on how hard it works. I certainly have no intentions of tearing it down over it.
The Gate Keeper
Discussion Starter · #9 ·
Good to know. I will keep that in mind. It has been hotter than h.....well you know.
I have checked the entire engine and no leaks or excess oil are anywhere on it.
Thanks guys!!!!
1 - 9 of 9 Posts
