i have a hydraulic blade for a 318 and want to make it work on a 420. seems like i saw an adapter here that someone made but can't find it. any help would be appreciated. the 318 is the same top to bottom at the mounting bracket but the 420 is wider at the top.
When I bought my 420, it came with a "318" blade, so I bought a "frame squeezer". Yes, it works, but longer hoses are needed & it was a pain to mount & remove the blade from the tractor, including hard to get the hose connections hooked up.
A better solution (at least for me) was to cut the end plates off the mounting bracket & add 1" to each side! ~~ grnspot
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
My Tractor Forum
