Check the auto resetting thermal fuse under the battery. Check the other 2 fuses 2/3 amp and 20 Amp plus those holders. finally, Finally check neutral switch, seat switch, (Brake switch if equipped), finally the Ignition Key Switch.
Double check the little wire (purple color on mine) to make sure it is on the solenoid spade, that one always get me.
PTO wire is blue
PTO wire is blue
