1 - 7 of 7 Posts
Today I was moving dirt and using the float to back drag and level the lever would not stay in float as I was holding the lever I i stopped fast and shoved the lever hard and now it will not come out of float.I haven't tore it apart yet but it feels like the detent has it locked.Any ideas
This may help:
I finally had time to disassemble the float control and clean now I can't figure out how to reinstall the spring balls and the plunger then screw on the cap.Just wondering how you guys did it
Put a bit of grease on the balls and springs to help them stick on place.
I tried that the valve is still on the tractor it looks like I have to put the spring in then the tapered cap while holding that in place add the 3 balls and somehow slide the cap on and tighten cap
1 - 7 of 7 Posts
