I put a 54 blade on the 318 for the first time to clear some slush off the driveway. I couldn't get the float to work so I was constantly lifting and dropping the blade just to get it done. It felt like the lever wasn't getting full travel and was quite stiff.
Yesterday I sprayed down the hydraulic control valve and levers with some ATF/Acetone mix and let it sit overnight. today I went out and worked the inner lever back an forth and finally got full travel so the float function works now. When I get time I plan on pulling the levers apart to clean out any remaining rust. One question I have is should the detent hold the lever in the full forward position?
