Thanks for your replies and insight. After giving it some thought, I rotated the engine until each valve opened and used a flat washer between the valve and block to hold them open. The camshaft came out easily by tapping it a couple of times with a mallet. Normal procedure would be to completely tear down, hot tank it all, blow out the oil passages and totally rebuild. When I first noticed oil use increasing early this season, I checked compression and found it to be 110 psi on both cylinders. The sparks plugs were clean and normal color, so engine wear was not the problem. Like most mowers, dirt and debris can cover oil leaks, but I found oil building up beneath the front PTO. Assuming gasket wear was the issue, I continued to use it for mowing while monitoring the oil and keeping it topped off until the front gasket and seal came in. After replacing them, the oil leak continued. I took it apart and added gasket sealer, but the oil leak continued and increased. It was not until I put it back together a third time, but left the PTO off and watched as the engine ran that I noticed the welsh plug spinning around. I then realized the oil was travelling around the PTO area and down from the welsh plug and the gasket and seal were OK.
If there is any useful information in my comments for other owners, it is to inspect the welsh plug frequently and suspect it immediately when oil leaks appear on the front of the engine. I had searched the internet for information about oil leaks on the front of 318s and P218G engines and no one ever mentioned the welsh plug. I'll replace the necessary parts, pull the oil pan and totally clean it out. The camshaft bearings are worn, partly disintegrated, but on the outer portion. Hopefully, no metal made it into the crankcase.
