1988 316 with Onan p218. Hours unknown, but probably 1000+
I have about 1.5 acres I cut weekly, takes about 1.5 hours. the last 2 times I've cut, it wants to die at full throttle (with PTO on), after just about an hour. it runs flawlessly before that. The stumbling usually occurs after starting from a stopped position, PTO on. When it starts to stumble, I switch the PTO off, and throttle down to half throttle, and it catches its breath and runs fine.
I checked for obvious issues 2 weeks ago, and found that the air cleaner was pretty fouled. So I changed it with a new one. I cut this week, and the same thing happened after about 1 hour.
I have fuel filters before and after the fuel pump. I can clearly see fuel flowing through each filter. I have not changed either filter yet, but they are only about 1 year old. The flow after the pump does have some air bubbles in it, if that means anything. I have read some things about vapor locks due to fuel filters, but I've had both filters in the line for 3 years with no problems.
Sounds like it's not getting enough fuel. I replaced the fuel pump with a brand new Onan unit about 3 years ago. I also rebuilt the carb at the same time.
What is strange is, why does it only show problems after an hour of cutting? Some of that cutting is up and down hills, with a lot of start/stops.
Any advice on what to try is appreciated.
