Could be a partial problem, but that ignition circuit also involves the safety switches (seat, neutral, and later serial numbers the brake switch). Have you check those operational for opening/closing, wiring to the switches for for breaks, cuts, broken insulation allowing shorts to metal? Also check the PTO switch, one side is to actually power the PTO clutch, the other side is used in the safety circuit too. Do you have the TM for the tractor?
