Hello everyone, still sorta new around here, but im reading the posts daily and really enjoying all the information out here. Anyhow My problem is the front end of my tractor squeeks like crazy. I know where the sound is coming from I just haven't been able to figure out how to stop it. When I first got this tractor, it would get stuck on any uneven ground, after about a year I figured out that the front Axle did not pivot. It was locked down, on two sides of the frame with, what appears to be a adjustment bolt. I loosened the bolts so the axle would pivot, and no get stuck, however, the head of the bolt rubs and the axle rubs the metal part of the frame. I tried to put grease there, and spray lub. but it only lasts for about 1 mowing. I would like to know if anyone else has had that problem, or is there and adjustment procedure? If you guys are confused by what im trying to described i can get a picture. Thanks
