316 electromagnetic clutch
454 Views 2 Replies 2 Participants Last post by  MrDooder
Needing help on my 316, front pto clutch isn’t engaging. It was working before I swapped the motor out, took it apart and cleaned all the oil out of it and reassembled. Now with the clutch plugged in I get no light and the motor dies but when I unplug the clutch the pto light comes on. The field coil passes all of the tests in the service manual.
1 - 3 of 3 Posts
Seat switch and the PTO switch have to work including the wiring. Check those, check all grounds since you swapped motors, and check the TDCM plugs for dirt/corrosion.
ended up just being a crushed wire behind the clutch! boy did i feel dumb, been messing with this thing for 3 or 4 months now! a little bit of heat shrink and electrical tape and she works like new! now to get the blades sharpened and the deck mounted!
1 - 3 of 3 Posts
