1 - 6 of 6 Posts
OK guys,
I think I screwed up in my haste to get my 316 up and running again.
I put JD Low-Vis in the transmission!:hide: I'm not sure,but I don't think that will work too well. Am I right? What is the consensus for the "right" fluid in the older Deeres.
Greg
Low Viscosity HyGard is what Deere now recommends for use in the older 316/318 GTs. So if it's HyGard, you should be fine. Automatic Transmission Fluid Type F is also fine.
Great dogs stash.My sister had one.
But what if (like mine),the trans has a thousand hours on it? Is the Low-Vis still the better choice?
Greg
OK,done deal. I'll leave it alone.
Thanks for the info guys:)
Greg
1 - 6 of 6 Posts
