312 no forward drive
649 Views 4 Replies 2 Participants Last post by  burned300
my 312 was driving fine in forward and reverse, then the engine threw a rod, tractor down for 2 months, put in rebuild engine and no forward drive, reverse works fine, fluid is full, valve is backed all the way off, linkage that I can see seems to be moving correctly, one other thing it cannot be pushed forward wheels slide, pushes backward fine, beats me, any ideas greatly appreciated, thanks
Relieve valve on top of hydro pump stuck, plunger might be stuck down.
Thanks Ill check that tomorrow
you were correct, we oiled both plungers and it works fine!!! Thank you very much :thThumbsU
Thanks for update, glad it all worked out.
