1 - 2 of 2 Posts
My lift arms don’t stay in the same position as the setting on the the control lever. While using an attachment, it will go to the position indicated for a while and then randomly lift to the top position. I can move the lever to the top and then put it back to the desired position where it will do it again after some random time.
If I put the lever in the all the way up position, I hear the pump doesn’t turn off. When the pump stays running, I can move the lever downward a little and the pump noise stops. I adjusted the rod that goes to the base of the lift arm from the side of the case that moves with the arms and it had no effect.
There are no leaks and the fluid level isn’t changing when I check it cold.
The 3038 is not a garden tractor but is a compact so you need to move you question to that forum so you get an answer. Roger
1 - 2 of 2 Posts
