1 - 3 of 3 Posts
Anyone seen this before? Its leaking somewhere under the output shaft housing for the fwd. I haven't found the exact spot. Any help would be appreciated. I have cleaned the area to better find the source. It does leak after it's been parked. 8 hours.run time lost about 1 quart.
Does that 8 hours of run time include FEL work?
A quart from a shaft seal is excessive and should be noticeable after being parked. The same quart from a questionable hydraulic fitting after 8 hours of FEL work is not uncommon, and may even take some hard looking to find.
Looks dry as a bone there... you do good cleanup.
Maybe post a pic of it after it's started to seep a bit so we can see...?
Ya a quart is a lot.
1 - 3 of 3 Posts
