Ok some back ground
Dad has overhauled the engine by a local shop.
in the process he switched the alum, boxy carb (MS??) for the cast iron Zeinth.
Just prior to the OH we installed the Pertronix electric ignition, works well BTW. http://www.pertronix.com/prod/ig/ignitor/default.aspx
Startes great...but
Now it smokes like a diesel idling and misses with fast to moderate throttle application, it can smooth out after it "catches up" its like it loads up.
My question is what size jet should be in the carb....or is there replaceable jets in idle circuit within the carb?? Seems like it is over fueling on idle with some improvement at full throttle.
thanks,M
Startes great...but
thanks,M
