I believe it's the same frame mount point, so no.
From what I can tell, it is the same frame mount. It looks to me like the weight bracket may fit over the front hitch using the same mounting points.I believe it's the same frame mount point, so no.
Thanks for the explanation. Can you explain your comments about hanging weight on the yoke? Are you suggesting an alternate way to hang weight?The weight bracket will never clear the yoke. Besides, anything you hang on the yoke will outweigh the weights hanging on the bracket.
What are you trying to accomplish?
Outstanding! I had a suspicion that tubular bar in front would become part of the solution. Much appreciated.SuperDoug
We made a simple mount to add extra lights ( when using the snowthrower for example). It was a handy starting point to add a piece of flat stock and hang four suit case weights.
DMAC
