This will be my first post after a long absence. The loader for my GT3235 has also been in storage for much of that time. Over the fall and winter, I put up a shop, and as major landscaping is now needed, I cleaned-up the Kwik-Way and installed it again.
I believe that the picture of the 3000 FEL that Kawasaki Old Man posted is actually the loader I now own. I bought it quite a few years ago from a really great MTF member in Benton Harbor MI who goes by the title Blown 4.3. I think I recognize both he and the neighborhood. Anyway, here are the details on a 3000 series Kwik-Way.
The loader itself is a design similar to what Kwik-Way used for many different tractors. I have seen brochures showing an obviously related loader for earlier Cub models, Bolens, Simplicity and Ariens – and I think there may be more. It is a stout design with a hefty forward H frame & arms, 2” cylinders (1.125 rods) and bucket widths of 40” or 48” depending on application. The twin vertical posts have tab and clevis pin retention for quick removal, the left-hand post also being a hydraulic fluid reservoir in versions that came with a dedicated loader pump. The Cub versions did not use a tower connecting brace, but some of the Simplicity versions did, and some of the Simplicity loaders also used tractor hydraulics. Dry weights quoted run from 380 to 450 pounds, depending on application, with lift capacities listed from 350 to 500 pounds. Minimum counter weights from 280 to 300 pounds are called for. One difference in the 3000 series loader is that the loader posts have an offset (to clear the floor pan), where on other Kwik-Way units the posts are straight.
Mounting for other models vary, but this is how the 3000’s series are attached: Four mounting plates are bolted to holes drilled in the tractor frame, which can be left in place without interfering with other attachments. A subframe that carries the loader posts and the dedicated hydraulic pump is hung from these mounting plates, attached with 3/4” clevis pins. The subframe can be moved around by one person. A smaller front subframe is attached using the 4 factory-provided attachment holes in the tractor frame rails. Two forward stays are angled down to this subframe to stabilize the posts.
I believe the frame plates supplied by Kwik Way to be a bit light, and the two attachment bolts for each plate are too close together. Accordingly, I fabricated plates from 5/16” steel (1/16” thicker) with wider based mountings, a spacing of 8”, and two extra bolts per mount plate.
The pump is an MTE unit of 0.4 CI, subframe mounted and driven from the rear facing PTO shaft behind the front axle. The driveshaft for the pump uses a chain coupler for the pump end and a splined sleeve at the PTO end, with both ends using small setscrews for retention. The dedicated hydraulic pump avoids the tractor hydraulics and is a clean set up that tucks the pump up between the frame rails.
As delivered, the pump has hoses solidly attached to the pump, the pump being held in place by clevis pins. The pump gets dragged along with the loader mainframe when it is removed – an odd design. I added hydraulic couplers on the supply frame port and the pump pressure port. Now the pump to remains bolted to the subframe when removing the loader – much easier. I also welded up a new driveshaft using a Cub quick connect PTO collar at the forward end, eliminating setscrew retention and allowing for misalignment.
According to the Kwik Way literature, the bucket is supposed to be a 40” unit, but mine came with the 48” bucket, which is shown as an option in some K-W literature. I was told by the seller that my loader was the last 3000 series unit that K-W built (#1025) and I believe that this is correct. This could explain the 48” bucket – they were using up what they had. One person can attach the loader using the installation support tubes and it’s not too difficult.
Regarding the GT3235 tractor, for loader use I installed Carlisle 18x8.50-8 Multi-Trac CS tires in front. They are an 8-ply tire specially made for GT loader service and carry a hefty 1280 LB load rating. They mount (not real fun to do) on 7” wheels, with the spindles converted to 4-lug hubs and tapered roller bearings. On the rear I have 25x10.5-12 All Trails. My total rear counterweight package for the 3235 can be up to 489 LBS, with the 3-point, A-frame, wheel weights and 6 suitcases – which so far has proven to be sufficient.
Man, do I love this loader as there is just so much one can do with one. The loader cycle times are quick and the lift height is about 5’, with the bucket rolled down, over 8’ up. Lift and roll controls are smooth & feather well and the bucket follows decently in float position. The bucket will dig into a pile of soil and fill fairly well, but without a tooth bar, I have not tried really hard packed soil. The whole loader operates like a slick, well-designed unit. The 3000 is stout enough for loader service, easily moving loads and stable in transit. The 40” bucket might have an advantage digging in when loading, although I have had no problems with the 48” (I am careful not to overload). The rear counterweight I am using works with the All Trails well enough that I have not used chains yet, but I may need to with harder soil or other material like river rock.
It's too bad that more of these loaders were not sold, for while the 3000/Kwik Way combination may not be quite as capable as say, a 700 series Deere, it is pretty darn good. It has a lot of work to do now, but maybe it will get a Cub yellow paint job this
winter.
winter.
