30" mower question
663 Views 2 Replies 3 Participants Last post by  pghdave
I have now operated a few different Gravely tractors with the 30" deck. And mine it the roughest one to get to engage. It's actually quite violent! The crashing sound of gears, and it often times kills the engine.
Is there an adjustment? Why is mine so rough to engage while others I've messed with are easier? I do shift the PTO between low and high to try to get it "out of gear" while engaging. But it's still rough.
1 - 3 of 3 Posts
One thing I do is put the forward/reverse lever in forward during engagement.
If the high/low lever is in neutral, the machine will not move. The PTO will be stopped, also.
Well, it should be stopped, we hope! :hide:
I have to do that when I disengage the PTO on a machine with a PTO brake.
I hate the thought of that brake trying to stop that spinning blade. :dunno:
One part that wears is the little block of metal that moves the dog gear maybe this is worn not allowing gears to engage smoothly.
Just a thought
Good luck Dave
1 - 3 of 3 Posts
