1 - 3 of 3 Posts
Has anyone tried to adapt a cat 0 three point to a Craftsman GT? When I look at the JD318 setup, it seems to me that you'd only need to add a small external pump and cylinder or even an electric actuator from the existing lower hitch plate to the upper lift arm below the top link. thanks for your thoughts.
They did make a stock elec. cat 0 3 point for the older Sears Sububans and a elec sleeve hitch for the later Craftsman GT's. They used a electric actuator.
Sears cat 0 was smaller compaired to the name brand GT's of that time.
... when I look a the large equipment used on farm my FIL works at, very little true 3 point. Most everything, including 20' "bat wing" dual row cultivator, 8' Box blade.. is a standard, fixed pulling hitch (one point) with hydraulics to raise or lower a set of wheels (raise the wheels to engage the ground)
Their only commonly used 3 point attachment I can think of is a round bale speer (so the tractor with a FEL speer can transport 2 bales at the same time).
Wait, I did see one or 2 attachments that use the (2) lower 3 point mounts to help a shaft PTO attachment.
Anyhow, they say figuring the exact measurements for a proper 3 point is very difficult. I think it would be easier to use actuators to raise or lower wheels behind an attachment, and that's the large-scale farming way, anyhow (Althouhg I think a 3 point would be really cool..)
1 - 3 of 3 Posts
