I got the Harbor freight quick disconnect and the easy-hitch and they fit find and work well for pulling around the car hauler (when I can keep the front end of the tractor planted!) However, with that system, when I back into the rear blade to mount it for work, the tractor arms are several inches too wide. The rear blade can be installed just fine (sorta) without all the extra hookup stuff but that takes a lot of personal gut power to lift, separate, fit, and generally ruins my back to hookup the rear blade. I got this extra hookup gear just for my bad back (and I mean b-a-d. My L3 is completly shot and it hurts all the time.) Anyway, any ideas on how I can gte everything to connect/disconnect as easily as pie [without lifting and lugging of half the equipment in the process?] Thanks. Or do you need pics? I think I figured out how to do that once so maybe I could do it again.
If it's important, it is on a BX2660.
David
David
