Hello all
I did a previous post regarding tire sizes for a 27hp DGT6000 but I think I posted in the wrong forum the "accessories form"
The 16 x 6.50 - 8 tires are maybe the most common front tire used on garden tractors and has been so since they were first used in about 1964/5. You should have no trouble finding them. Changing to tires of larger diameter can lead to all kinds of clearance problems if you plan on mowing with your tractor. They will hit the deck. If you need new tires replace them with the same size tires. If you need more traction use HDAPs in the stock size. Roger
