1 - 3 of 3 Posts
I have downloaded the specs for both the 2720 and 2520. I'm interested in the 2520 but need to consider the 2720. For the 2720 the data shows that a 10% price increase (based on list) relates to a 16% greater engine HP (5), 13% greater PTO HP (3) with a weight gain of 108 pounds or 5.5% and Rated Engine Speed reduction of 100 RPM. The hydraulic system is identical per the dealer. I wonder if I can operate at the lower 2500 RPM and save fuel? Is a slightly lower operating RPM beneficial to the engine? (is 100 RPM's worth mentioning?)
I know the 2520 is enough for my needs, but would you spend 10% to get 5 additional engine HP, 3 additional PTO HP and run your rig 100 RPM less? The percentages look to be attractive, the extra 108 pounds is a wash as is the extra 0.5 inch clearance.
Thanks for looking, considering and responding.
If your doing alot of PTO work, mowing, tilling and you can afford the extra $, I would say yes. You also have to remember, you run the engine slower your also running your PTO equipment slower.
I though about trading for a 2720 last year, but I only need the extra hp for my tiller, and thats only like 5hrs a year. Not worth it to me.
· Good at breaking stuff!
Tough call. I chose the 2520 based on price because I also wanted 46bh.
1 - 3 of 3 Posts
