hey guys,
hope i am posting to the correct forum. i have a john deere 265, and it has ran fine the last couple of times i used it. tonight i tried to use it and i could not get it to full idle, without it knocking off. if i got it nearly full idle and tried to engage the blades, it would knock off. i checked to make sure the fuel shut off was open, and it was. the air cleaner was not dirty, or clogged. the fuel was fresh and had not been in for more than a couple of weeks. does anyone know what i could check to see why the mower won't run at full idle? when it was at full idle there was a litte arm that would move back and fourth behind where the throttle cable connects close to the fuel pump. i don't know if this is relevant or not. any help or suggestions would be appreciated. thank you
