Good info! Did you wrap the whole thing or the outlet pipe?
Joel
Joel
Wrapping definitely keeps the heat in. I'm thinking as long as you don't wrap the muffler itself (just the heat shielding), there should be enough airflow to keep the exhaust steel from getting brittle.Does exhaust wrap insulate the pipes (keeping heat inside the wrap) or help dissipate heat?
Joel
After hearing many pilots complain about cracks in their exhaust, I decided to coat my entire exhaust system with a ceramic coating (I'm going back 15 years so I don't remember the trade name). This coating so effectively removes heat from the exhaust, I can touch the pipes just minutes after a flight.
The bottom line is, if you can remove the heat, you remove problems. The ceramic coating increases the surface area of the pipes, allowing the heat to dissipate faster
The EGT probes are usually mounted 2 inches from the flange. In that location, at a cruise power setting, the EGT is usually about 1,280F (+/- 50F) in a normally aspirated engine and over 1,500F on a turbo-charged engine. Fuel mixture is used to control EGT. If above 1,280 enrich the mixture (it's adjustable on an aircraft engine to compensate for altitude and temp) and if below you can lean the mixture to achieve best power and conserve fuel.CHT and EGT are much greater on an aircraft than out LT's
Do you guys think the paper thin exhaust steel will hold up to this kind of heat? I've never wrapped one so I dunno.. Regardless, it sure sounds like it could be a viable option for the late model 2K owners.
Joel
I went into aviation maintenance in 59. Got my A&P in 70..Got out in 82.The EGT probes are usually mounted 2 inches from the flange. In that location, at a cruise power setting, the EGT is usually about 1,280F (+/- 50F) in a normally aspirated engine and over 1,500F on a turbo-charged engine. Fuel mixture is used to control EGT. If above 1,280 enrich the mixture (it's adjustable on an aircraft engine to compensate for altitude and temp) and if below you can lean the mixture to achieve best power and conserve fuel.
Yep, it's 1930's tractor technology.
Now just who was it that said to do that............![]()
Actually by many others prior to being graciously accompanied by the musical stylings of 'da nut! :fing32:Now just who was it that said to do that............![]()
