1 - 10 of 10 Posts
Hi everyone,
I picked up my first CC last week, a 2005 2542, and was wondering if the following is normal. If I go forward and release the forward pedal the tractor continues to roll and slows down gradually (ie, coasts), but when in reverse if I release the reverse pedal it comes to a jerking stop almost instantly. Is this normal? I was a bit surprised by the reverse behavior.
-Todd
My 2004 GT3235 has the instant reverse stop. But, it also has instant forward stop too.
Once it stops though it will ever-so-slightly then begin to creep (only creep and only on a hard flat surface) in the direction it had been going before releasing the forward or reverse pedal.
Hi everyone,
-Todd
From time to time mine behaves exactly the same with rolling forward slowly, other times it stops immediately. Usually that seems to occur when I let off the pedal gently vs. immediately. I have a 2010 GT2544.
I have a 2542, it does the same as what you are talking about.Took it to dealer, said it was normal, for what thats worth.If you want to stop quick, take foot off pedal quick.Phil.
Hi everyone,
-Todd
OP - might be that a drop or two of lube on the drive pedal linkage would help...
10K and Climbin!
Ditto on the reverse problem on my 2165.. I've tried lubing it and still no joy.. I'm thinking it is a sticking hydaulic vakve in the hydro.. I havn't had time to investigate as I'm sitting here with a busted leg.. :banghead3
That little shock absorber / gas strut attatched to the motion control linkage is supposed to prevent abrupt transitions from start/stop. I would look into that, check for slop on any of the forward/reverse mechanism and make sure it's all lubed. It should not come to a skidding stop. My 2544 was smooth on the transition, but would rarely come to a complete stop unless I gave it some reverse. Mine crept foward at times too.
Joel
I got our 2550 to back up so so fast it'll give you whip lash until you mastered the pedal.
hey, maybe that's another lawsuit just waiting to happen... Headlines... Tractor stops TOO good, sue MTD now!!!! :)
1 - 10 of 10 Posts
