1 - 3 of 3 Posts
Another 25XX busted hood??
Is your tractor under warranty? There have been a few on here recently who have experienced the same thing, myself included (2544). I had just purchased mine, so I didn't try fix it.
Have you heard of a product called J.B. Weld? It's an epoxy that I've used on plastics before and it's worked good in the past. I don't know about on these hoods though.
If the tractor is still in warranty you are covered - I just had mine paid for under warranty and I am going to install it myself. They are replacing them on a pretty regular basis and this is something that every Cub dealer is aware of.
If not, I would write Cub and ask them for consideration under their Goodwill policy. I do not know of anyone that had asked about this, but hopefully someone will come along here with their experience, yea or nay. At any rate, it's worth a try.
If they are not extending Goodwill on this, I would certainly try a plastic to metal epoxy. If you have inserts, epoxy the insert back into the hood, if not epoxy 1/4" studs into the hood and add nylock nuts. I put studs on mine and it is MUCH easier to R&R that way.
Good Luck!
1 - 3 of 3 Posts
