Glow plugs are located on the cylinder head. I would start by trouble shooting by checking for any blown fuses, next check for voltage at the glow plugs. If you have voltage there when the key is first turned on then you probably have bad glow plugs. If you have no power going to the glow plugs the next thing trace the wiring harness back to the glow plug relay and timer looking for unplugged connectors, frayed or pinched wires. Then check the glow plug relay and timer, i believe they are located behind the dash panels. Also check for power coming to the relay and timer. Hope this helps.
