1 - 2 of 2 Posts
I had the clip that gives detent feel break on my 2305 deck adjustment knob (No 18 in diagram below). My question is the best way to replace the clip. Should I remove the floorboard or go from underneath? If I remove the floorboard how do I remove the knob to lift the floorboard up and out of the way? I don’t see a set screw. Does it screw onto the shaft (No 2 below) or is it a press fit?
Discussion Starter #2 (Edited)
Well, for those who may come along later, the knob is a tight slip fit.
The adjustment assembly (7) is easily removed from underneath by the two 16mm bolts/nuts (10, 9, 8) in the diagram.
Pull (hard) on the knob (1) and remove the assembly (7) to install the detent spring (18).
Reinstall the assembly with the bolts/nuts and reinstall the knob.
Readjust the deck height. Installing
1 - 2 of 2 Posts
