Tilling up my yard to level it and reseed it. I have about 4 acres total to do, and in the last two days have spent about 3.5 hours on it (probably a little less) and got between 1 - 1.5 acres done.
This tiller rocks. It hasn't rained much this year so the yard is like cement, but this tiller is tearing into it, and it's like baby powder after a single pass. No clumps, no clods, just nice sweet smooth topsoil.
This is former farmer field so it runs the length of the field in furrows. If I mow the long way it's bad but not nearly as rough as when I try to go the wicth of the field.. That will jar your teeth loose.
So I was planning on getting a box blade to level the field after I tilled it, but now that I've tilled part of it a boxblade would be overkill.. now thinking a dragharrow, or maybe a landscape rake..
There are two BIG ditches running through the middle of the field (also lengthwise) and I think these will be the hardest to level, but do want to level the entire field.
Also thinking a landscape rake shouldn't take much HP to pull it.. If I go with a rake will I be ok with a 6 foot rake?
USMC
If you get a landscape rake make sure it has the gauge wheels if not buy a set for it and it will do you a very good job. I use a 4ft but it could probably handle a 6 footer. slkpk
Ditto, we use landscape rakes for a lok of tilling projects, driveways, spreading turf dressing, top soil etc. Wheels when using a 2305 or pretty much any of the cuts make a world of difference. We have 4 and 5 foot rakes, for a small business I find these to be the best overall based on the size of the projects we do.
W5CPT
My John Deere Implements Catalog lists two 6' Rakes for the 2305. And that is without the Gauge Wheels. Gauge Wheels (which I also recommend) would put a bit less drag on the tractor meaning you may be able to handle something a little bigger, maybe a 7'. And the 7' Rake maybe easier to find used as "Compact Only" implements are rare (or at least around here where I am surrounded by farmers who use BIG equipment).
Bob,
I have the JD-LR2060L rake and it works very well. I never got around to the wheels but if you can, they probably would make it a little easier to level. Although mine w/o them turned this:
Into this after the dozers got rid of the really big stuff:thThumbsU
