Well first thing you need to do is clean up or replace the corroded terminals.
Also go to www.ingersolltractors.com and using the S/N of your tractor copy the wiring scematic for your tractor, making sure the terminals for the ignition switch are in their proper orientation.
If your having charging issues , go through the older threads here for some tests to perform. :goodl:
BTW Welcome to the forum.
