Hey guys,
Got what I think may or may not be an issue with my 2186's Kohler. 18HP, built around 2001. Almost 250hrs on the clock. I'm second owner, bought it with 169hrs on it.
I notice that the engine is quiet when it's cold, but after running it at WOT for about 15mins or so, it develops a slight tapping noise, present at all speeds. It's not excessive, but when I open the hood to blow out the debris after each use the valve noise is definitely noticeable. I considered that it might be air getting into the lifters from foamy oil or from oil level being too high. I've used a cheap Tractor Supply Synthetic 10-30, Rotella 5w-40, and now I have Kohler oil in it. I've not noticed anything that really makes the noise go away. If I let it sit for a few minutes and start it back up, the noise lessens. And of course, if I let it sit till it's cold, the noise is completely gone. It's not getting any worse or any better. I added Seafoam to my oil this time to try and free up the lifters if they were sticky, but that hasn't helped either.
I do notice that my oil has air bubbles in it. I don't know if this is normal, but I have other small engines that don't get quite so much air in the oil. I've had the oil level below full, halfway between add and full, and right at the full mark. Doesn't make a difference.
The thing runs great. Is this something that is just normal for these engines? I did a ton of reading on this and there have been problems with the HLAs on these Commands, but there's no consensus as to what fixes the problem. Some say Kohler Oil. Some say Mobil1. Some say Seafoam. Some say it's not a problem. Others say it is.
I'm confused, school me on this please!
Justin
Justin
