WNYTractorTinkerer, the label on the hydraulic pump assembly, the actual hydrostatic transmission, is similar, but simpler. However, it does say Hydro Gear on it.
I am familiar with hydrostatic transaxles in general, and have repaired to from Hydro Gear, but they have been integrated transaxles. This is my first one with a separate unit, and it threw me for a loop. Looking in the Cub Cadet Service manual, it shows the same transaxle with either the BDU-10L-221 for hydrostatic, or a clutch housing and assembly for manual. So, this same transaxle could be used, depending upon which input was attached to it, hydro or clutch. That is fascinating to me.
This unit does have an oil filter, probably original, as it is yellow, says "Cub Cadet", and has some rust and a small dent or two. The oil level is low, but what oil I could read looked clean. I am going to change it all anyway to be safe. I already have the Napa Gold 1410 correct replacement hydraulic oil filter on order for $9.71, as well as 6 qts of Shell Rotella 15W-40 oil. The dipstick on this unit also fits poorly, so for now I have wrapped it in 3 turns of E-tape. I am searching for large enough heat shrink tubing to use that. From my research, I get the impression that even a new dipstick will fit poorly. This unit had a lot of dirt/oil spooge all over the transaxle, so I am going to say that the dipstick was leaking for awhile. I am going to pay close attention for leaks once I get it up and running.
Jmoe, yes this is the cast aluminum transaxle. Thanks for the photo, that is the tractor I am working on. Too bad the previous owner left it to rot for a good long time in his yard. There is a great deal of surface rust on the body, hood, side panels, and deck.
Thanks gentlemen!
Seth K. Pyle
