1 - 3 of 3 Posts
I have a 214 that keeps throwing the belt that goes to the transaxle. I'm certain it is routed correctly also.
It seems when I put it in gear and start to take off, it will work for about a minute, then BAM!!!! it throws the belt. Any ideas???
Thanks,
Mike
· Three of my friends
Check the angle of the idler,most likely it is out of line or has a bad bearing,the top belt goes under the idler.And check to see if the pulley on the shaft is still tight on the shaft,should not slide on the shaft.
1 - 3 of 3 Posts
