hello all, I removed the deck from my '84 214 last winter to do some repair work on it, well I have just now gotten around to re insatalling it, I can't remember how the two rods that run from the front of the deck directly under the engine to the frame on the front of the tractor attach to the deck itself (with the spring loaded candy cane shaped rods), I know I have it wrong b/c when I lift the deck it only picks up the back of it, the front stays down. I would love to see a clear picture if any body has one, many thanks in advance, god bless.
Do you have both draft arms connected to the tractor as well
Here is the best I could do to show how the parts lay I have a 112 with a 47 deck But I haven't had the deck on in a few years:thThumbsU
Run the adjustable arms (#6 in the diagram above) up the threads. That will make the front pick up. Also, the "J" hooks should go through the bottom of the arm (#6) and the hole on the front of the deck to hold them on!
