1 - 3 of 3 Posts
When the deck is raised all the way, the pulley for the power flow hits the arm. What have people done about this? Does just moving the arm to the inside work?
Also, I seem to have an older deck with only the three guide wheels. The side that the discharge is on sure could use another one. Has anyone had any luck adding a wheel? I have been looking for a newer deck, but there is nothing around me that I can find.
Thanks all!
A semi-retired senior cit
Maybe there is a lift stop adjustment can`t find anything on JD parts catalog about the mower deck or mention of one must have been an option. Do you ever use the bagger when it`s in the transport mode? I`d try moving the arm over maybe adding a few washer to get you the clearance just make sure the arm doesn't rub the back side of the belt, that would wear it out too. What model tractor did the mower deck and bagger come from that may help find and answer?
1 - 3 of 3 Posts
