1 - 3 of 3 Posts
I had to move 18 concrete parking curbs and they weights about 200lbs each. Soooo this what I made to lift them off the trailer and set them.
the 212 has electric lift so I had to make a lock out for the hitch not to rise up as I lifted them.
Did you retrofit a 112 electric lift on that 212? I'm not seeing the normal arm on the left side for that electric lift. Pretty nice lifting setup you built there.
the electric lift is factory set up , this model does not have the arm, just a switch where the arm goes.
1 - 3 of 3 Posts
