1 - 1 of 1 Posts
New Kioti RX7320HS-TL 75HP Class 4x4 Tractor Loader with FREE Box Blade
2497784
Learn More
NICELY EQUIPPED:
  • HD 8' Box Blade with Cutting Edge and Ripper Teeth
  • Heavy Duty 3,400 lb. LIFT CAPACITY LOADER – Self Leveling
  • 24 Speed POWER-SHUTTLE Hi-Torque® TRANSMISSION
  • Prestige Level Operators Station Controls with Comfortable Seat
  • Full Independent Four-Wheel Drive (4X4) (not just front-wheel assist)
  • Unitized FULL STEEL Main-Frame Chassis (not aluminum)
  • Independent 540/1000 RPM Rear Power Take-Off (PTO)
  • 2,200 RPM Mid PTO; Heavy Duty 3 Pt. Hitch with 3,898 lb. Lift
  • ASTM A27 CARBON ALL STEEL TRANSMISSION AND FRONT AXLE
  • Rear Axle Differential Traction Lock
  • Single Lever Joystick
FREE UPGRADES Including:
  • FREE ELECTRONIC TURN-ASSIST Control Kit
  • FREE Heavy-Duty Cushioned Operator Deck Floor Mat Cover
  • FREE Electronic Operator CRUISE CONTROL
  • FREE REAR AUXILIARY HYDRAULICS Included
  • FREE 3-Pt TELESCOPIC LIFT ARMS with REAR 3-Pt Control
  • FREE Upgraded Front Grill Guard (protects front hood) Included
  • FREE HD TELESCOPIC DRAWBAR Kit Included
2497785
Learn More
SPECIFICATIONS:
  • POWERTRAIN and HYDRAULICS: Model 4F243T 73 Horsepower 4 Cyl. Turbo Diesel CRDI
  • Rated Revolution rpm 2,600
  • Pump Capacity (Max. flow rate) gpm (L/min) 19.2 (72.8)
  • 3-Point Hitch Category II
  • Maximum Lifting Capacity 3,898 (1,768)
  • Hydraulic Lift Position Draft Control
  • LOADER: Maximum Lift Height to Pivot Pin 133.9 in. (3,401 mm)
  • Clearance w/ Attachment Level 123 in. (3,124 mm)
  • Clearance w/ Attachment Dumped 102.3 in. (2,598 mm)
  • Maximum Dump Angle 47 °
  • Reach w/ Attachment on Ground 80.4 in. (2,042 mm)
  • Maximum Rollback Angle 54 °
  • Digging Depth Below Grade 6.5 in. (165 mm)
  • Lift Capacity 3,400 lbs
  • Breakout Force at Pivot Pin 5,359 lbs. (2,431 kg)
  • Lift Cylinder I.D ø70mm X ROD 40 mm
  • Bucket Cylinder I.D ø70mm X ROD 35 mm
  • Bucket Size 82 in. (2,083 mm)
2497787
Learn More
$0 DOWN – SIGN AND DRIVE for $498 mo – FAST APPROVAL and DELIVERY – GET APPROVED ONLINE NOW at www.TeamTractor.com
COMPARE with KUBOTA and JOHN DEERE – Kioti has More Lift - More Power – More Push – All Backed by an Outstanding 6 Year WARRANTY!
2497788
Learn More
Hi, my name is Bryce and I’m here to help! Call or text me 24/7 directly for more information – 602-734-9944 – office or 602-753-9623 – mobile. Arizona’s #1 Tractor Dealer - 1100 W Happy Valley Rd, Phoenix, Arizona, 85085.
1 - 1 of 1 Posts
