1 - 1 of 1 Posts
A few days ago, the PTO extension spring broke, I replaced it as the parts layout showed but when in the off position it will not activate the safety switch, by pulling back and a little sideways I can get the tractor to start, I notice the PTO lever moves easy from side to side, I then replaced the bearing that the lever goes through, this so called bearing is 2 pieces of plastic held on by 2 bolts, these plastic pieces can only mount one way, I don't see anything that will take the sloppiness out of the lever. anyone else come across this problem. thanks
1 - 1 of 1 Posts
