1 - 3 of 3 Posts
Most likely the shifter boots are torn and water is getting into shifter assembly and freezing. Getting the water out and installing new boots should fix it.
I got a new boor, It was torn. Service manager said boot is good also get high resistant to moisture grease, lube top of inner boot before installing new boot.. Thank you.
1 - 3 of 3 Posts
